- To:
- Subject: Re: [cgal-discuss] 3D mesh of a domain with several holes
- Date: Fri, 28 Oct 2011 19:36:36 +0200
Hello and thank you:
I have a domain like this:
I have all points of my domain (the whole volume) and I want to exclude of the triangulation several holes (see the diagram above, with only one hole).
Thank you for your answer
Adam.
On Fri, Oct 28, 2011 at 7:29 PM, Andreas Fabri <> wrote:
Not sure to understand.On 28/10/2011 19:11, Adam Hopkins wrote:
Hello:
I dont know if is possible build 3D triangulations of nonconvex domains,
for example with several holes inside the domain. Assume that I have a
set of points (x,y,z) (for example defining a human head) where I want
to consider several irregular holes inside and where these holes are
totally included in this set of points (for example I am considering my
holes like tumours). I want to define my triangulation from my set of
points and I can know the boundary points of these holes. Is possible
triangulate this domain with cgal , where I can exclude the 3D
triangulation of these interior holes?
Thak you and best regards
Adam.
Do your points describe the surface of the head,
or the volume?
You might have a look at Alpha shapes, and in the first
case at poisson surface reconstruction.
andreas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] 3D mesh of a domain with several holes, adam.hopkins83, 10/28/2011
- <Possible follow-up(s)>
- [cgal-discuss] 3D mesh of a domain with several holes, Adam Hopkins, 10/28/2011
- Re: [cgal-discuss] 3D mesh of a domain with several holes, Andreas Fabri, 10/28/2011
- Re: [cgal-discuss] 3D mesh of a domain with several holes, Adam Hopkins, 10/28/2011
- [cgal-discuss] Re: 3D mesh of a domain with several holes, adam.hopkins83, 10/31/2011
- Re: [cgal-discuss] Re: 3D mesh of a domain with several holes, Laurent Rineau (GeometryFactory), 10/31/2011
