cgal-discuss - [cgal-discuss] Re: 3D mesh of a domain with several holes
  • To:
  • Subject: [cgal-discuss] Re: 3D mesh of a domain with several holes
  • Date: Mon, 31 Oct 2011 04:15:29 -0700 (PDT)
Hello:
Sorry for my second answer about the same topic, but with your answer I
don't have clear the idea of solution of my problem or where I need to read
about this. Please if you can, give me the link of the documentation related
with my problem or the topic.
My problem is defined as follows:
I have a 3D domain defined by points (the whole volume) like this
and I need to make a 3D mesh only considering my set of points and with
several holes inside, in this case represented above with only one. Is
possible in CGAL to make a 3D mesh from a set of points defining the whole
volume and considering holes inside?
Thank you for all
Adam.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-mesh-of-a-domain-with-several-holes-tp3948601p3955457.html
