- To:
- Subject: Re: [cgal-discuss] Re: 3D mesh of a domain with several holes
- Date: Mon, 31 Oct 2011 14:33:57 +0100
On lundi 31 octobre 2011 12:15:29 adam.hopkins83 wrote:
> Hello:
> Sorry for my second answer about the same topic, but with your answer I
> don't have clear the idea of solution of my problem or where I need to read
> about this. Please if you can, give me the link of the documentation
> related with my problem or the topic.
> My problem is defined as follows:
> I have a 3D domain defined by points (the whole volume) like this
> and I need to make a 3D mesh only considering my set of points and with
> several holes inside, in this case represented above with only one. Is
> possible in CGAL to make a 3D mesh from a set of points defining the whole
> volume and considering holes inside?
3D alpha shapes look like the right tool to use. See:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Alpha_shapes_3/Chapter_main.html
Laurent Rineau, PhD
- [cgal-discuss] 3D mesh of a domain with several holes, adam.hopkins83, 10/28/2011
- <Possible follow-up(s)>
- [cgal-discuss] 3D mesh of a domain with several holes, Adam Hopkins, 10/28/2011
- Re: [cgal-discuss] 3D mesh of a domain with several holes, Andreas Fabri, 10/28/2011
- Re: [cgal-discuss] 3D mesh of a domain with several holes, Adam Hopkins, 10/28/2011
- [cgal-discuss] Re: 3D mesh of a domain with several holes, adam.hopkins83, 10/31/2011
- Re: [cgal-discuss] Re: 3D mesh of a domain with several holes, Laurent Rineau (GeometryFactory), 10/31/2011
