cgal-discuss - [cgal-discuss] simple transformation on Mesh_3 vertices
  • To: cgal-discuss <>
  • Subject: [cgal-discuss] simple transformation on Mesh_3 vertices
  • Date: Mon, 14 Nov 2011 03:43:13 -0500
Hello,
I am using CGAL to create tetrahedral meshes off of grayscale images.
After mesh is generated I need to translate the vertices to match
coordinate system of
the imaging machine (MRI, CT, ...)
I do this by adding a fixed offset point(x,y,z) to all vertices in a
post-processing step
outside CGAL using the MEDIT file.
I was wondering if this can be done within CGAL/C++ so I don't have to use
Matlab/Python to perform this step.
thanks in advance,
Hamid
