- To:
- Subject: Re: [cgal-discuss] simple transformation on Mesh_3 vertices
- Date: Tue, 15 Nov 2011 10:57:03 +0100
Hamid G wrote:
On Tue, Nov 15, 2011 at 3:56 AM, Sebastien Loriot (GeometryFactory)As I said, the underlying triangulation is a regular triangulation,
wrote:
Use for_each instead.
Thanks,
Just to clarify this in my head,
itv=c3t3.triangulation().finite_vertices_begin() is an iterator which
upon dereferencing returns a pointer to a vertex ? hence the double
.point() in
itv->point().point()+K::Vector_3(x0,y0,z0)
I guess that double .point() is confusing me.
so the first point() returns a weighted point, the second point()
the bare point and point().weight() the weight of the weighted point.
Sebastien.
- [cgal-discuss] simple transformation on Mesh_3 vertices, Hamid G, 11/14/2011
- Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Sebastien Loriot (GeometryFactory), 11/14/2011
- Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Hamid G, 11/14/2011
- Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Hamid G, 11/15/2011
- Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Sebastien Loriot (GeometryFactory), 11/15/2011
- Re: Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Laurent Rineau (GeometryFactory), 11/15/2011
- Re: Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Hamid G, 11/16/2011
