- To:
- Subject: Re: [cgal-discuss] simple transformation on Mesh_3 vertices
- Date: Mon, 14 Nov 2011 11:34:21 -0500
On Mon, Nov 14, 2011 at 8:38 AM, Sebastien Loriot (GeometryFactory)
wrote:
> What do you want to do precisely?
> A simple translation of the points in the mesh?
Yes, just offset them by a fixed (x0, y0, z0).
>> I am using CGAL to create tetrahedral meshes off of grayscale images.
>> After mesh is generated I need to translate the vertices to match
>> coordinate system of
>> the imaging machine (MRI, CT, ...)
>> I do this by adding a fixed offset point(x,y,z) to all vertices in a
>> post-processing step
>> outside CGAL using the MEDIT file.
>> I was wondering if this can be done within CGAL/C++ so I don't have to use
>> Matlab/Python to perform this step.
>> thanks in advance,
>> Hamid
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] simple transformation on Mesh_3 vertices, Hamid G, 11/14/2011
- Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Sebastien Loriot (GeometryFactory), 11/14/2011
- Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Hamid G, 11/14/2011
- Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Hamid G, 11/15/2011
- Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Sebastien Loriot (GeometryFactory), 11/15/2011
- Re: Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Laurent Rineau (GeometryFactory), 11/15/2011
- Re: Re: [cgal-discuss] simple transformation on Mesh_3 vertices, Hamid G, 11/16/2011
