cgal-discuss - Re: [cgal-discuss] error MSB6006: “cmd.exe ”exit with code 1
  • To:
  • Subject: Re: [cgal-discuss] error MSB6006: “cmd.exe ”exit with code 1
  • Date: Thu, 19 Jan 2012 08:26:16 +0100
Le mercredi 18 janvier 2012 17:56:47 hfang a écrit :
> HI
> I am a new user of CGAL.
> These days I installed CGAL3.9 follow steps:
> 1)install boost 1_48_0
> 2)install QT4.8.0 by install qt-win-opensource-4.8.0-vs2010 which is
> download from nokia
> 3) install CGAL 3.9, by CMAKE Coufigure,Generate
> all these files are installed at D:
> the error happened when I open D:\CGAL-3.9\Buildebug\CGAL.sln, and compile
> the CGAL
> But After I use CMAKE Configure, Generate,
> the compile always failed with:
> error 22 error MSB6006: “cmd.exe” exit with code 1。 C:\Program
> Files
> (x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.CppCommon.targets 151 6
CGAL_Qt4
In the output of MSVC, can you show use a few lines above the error. That
might help.
Laurent Rineau, PhD
