- To:
- Subject: Re: [cgal-discuss] Re: error MSB6006: “cmd .exe”exit with code 1
- Date: Thu, 19 Jan 2012 08:25:15 -0600
For this error below, actually you might not need to switch back to boost 1.47 by installing all over again.
:/boost_1_48_0/boost/type_traits/detail/has_binary_operator.hp(50):
Parse error at "BOOST_JOIN"The walk-around is already posted here, it's a bug when the combination is boost 1.48 and CGAL 3.8 or later.
You can either apply the patch http://drupal.org/node/60818 or manually modify the two headers GraphicsItem.h and GraphicsViewInput.h according to the description in the patch. The two files are under /CGAL-3.9/include/CGAL/Qt.
Then the everything should be fine, at least this works on the Mac Lion. Good luck.
On Thu, Jan 19, 2012 at 2:01 AM, Clément Jamin <> wrote:
Hi,I encountered the same problem. Switching back to Boost 1.47.0 solved it. It seems to be a problem between Qt and Boost.Clément Jamin.On Thu, Jan 19, 2012 at 8:54 AM, hfang <> wrote:
Thank you very much for your information.
I look out the output of MSVC.
It seems the main problem is this:
6> :/boost_1_48_0/boost/type_traits/detail/has_binary_operator.hp(50):
6>C:\Program Files
(x86)\MSBuild\Microsoft.Cpp\v4.0\Microsoft.CppCommon.targets(151,5): error
MSB6006: “cmd.exe” exit with code 1Is there any fixing method?
Thanks!
View this message in context: http://cgal-discuss.949826.n4.nabble.com/error-MSB6006-cmd-exe-exit-with-code-1-tp4308902p4309378.html
- [cgal-discuss] error MSB6006: “cmd.exe ”exit with code 1, hfang, 01/19/2012
- Re: [cgal-discuss] error MSB6006: “cmd.exe ”exit with code 1, Laurent Rineau (GeometryFactory), 01/19/2012
- [cgal-discuss] Re: error MSB6006: “cmd.exe ”exit with code 1, hfang, 01/19/2012
- Re: [cgal-discuss] Re: error MSB6006: “cmd .exe”exit with code 1, Clément Jamin, 01/19/2012
- Re: [cgal-discuss] Re: error MSB6006: “cmd .exe”exit with code 1, Roger, 01/19/2012
- [cgal-discuss] Re: error MSB6006: “cmd.exe ”exit with code 1, hfang, 01/20/2012
