cgal-discuss - [cgal-discuss] concrete example of coplanar points
  • To:
  • Subject: [cgal-discuss] concrete example of coplanar points
  • Date: Fri, 20 Jan 2012 11:13:15 +0100
Hi There:
I have this concrete example:
p1x = 0.00000000000000000;
p1y = 0.20000000000000001;
p1z = 0.00000000000000000;
p2x = 0.20000000000000001;
p2y = 0.20000000000000001;
p2z = 0.20000000000000001;
p3x = 0.40000000000000002;
p3y = 0.80000000000000004;
p3z = 1.00000000000000000;
p4x = 0.20000000000000001;
p4y = 0.40000000000000002;
p4z = 0.40000000000000002;
Jacobian = (p2x - p1x) * (p3y - p1y) * (p4z - p1z) + (p3x - p1x) * (p4y - p1y) * (p2z - p1z) + (p4x - p1x) * (p2y - p1y) * (p3z - p1z) - (p4x - p1x) * (p3y - p1y) * (p2z - p1z) - (p3x - p1x) * (p2y - p1y) * (p4z - p1z) - (p2x - p1x) * (p4y - p1y) * (p3z - p1z);
for this case, the jacobian is equal to 0 and for this reason these 4 points are coplanar.
However, in CGAL this test (if (CGAL::orientation(p1, p2, p3, p4) == CGAL::COPLANAR)) is not satisfied for the same 4 points. My questions are the follows:
- How is possible that in CGAL these points are not coplanar? because these points are coplanar.
- In order that I can't remove points, How Can I say to CGAL when computes the triangualtion that these points are coplanar?
- I will use the resultant triangulation in other software where the jacobian is computed and I can't use the CGAL library. Is possible to change the CGAL test of coplanar points when the triangulation is computed?
Sorry for my several questions, but I need to solve this problem.
Thank you in advance and waiting suggestions
Juan Cralos
