cgal-discuss - Re: [cgal-discuss] concrete example of coplanar points
  • To:
  • Subject: Re: [cgal-discuss] concrete example of coplanar points
  • Date: Fri, 20 Jan 2012 12:04:18 +0100
Try running the attached example, and you'll see you points are not coplanar.
In CGAL, we have nothing to change the predicates to consider almost
coplanar points as coplanar.
In your case, I remember that points are coming from parallel slices.
My last advice will be that you should round your points from each slice so that they exactly lie on a plane.
Please also do read this FAQ entry:
http://www.cgal.org/FAQ.html#inexact_NT
Sebastien.
On 01/20/2012 11:47 AM, Juan Carlos Lopez Alfonso wrote:
Hi Oliver:
Thank you for your answer. But, maybe you dont understand my point.
How is possible that this points are not coplanar when the jacobian is
exactly equal to 0? and you dont answer my question: How Can I say to
CGAL when computes the triangualtion that these points are coplanar? at
least with my criteria!!!
On the other hand, I cant include or remove points, and I need that the
jacobian of each thetraedron is different to 0. I am using MS 10.0 and
the jacobian is equal to 0, how is possible that in CGAL these points
are not coplanar? I cant understand this issue.
In my code I will use the Jacobian and in some case some expressions are
divide by the jacobian, and for this reason I need to have a jacobian
different to 0, while in c++ the jacobian is 0 for CGAL is not.
Regards
Juan Carlos
On Fri, Jan 20, 2012 at 11:32 AM, Olivier Devillers
<mailto:>>
wrote:
Le 1/20/12 11:13 AM, Juan Carlos Lopez Alfonso a écrit :
Hi There:
I have this concrete example:
- How is possible that in CGAL these points are not coplanar?
because these points are coplanar.
as already explained your points ARE NOT coplanar,
they are just almost coplanar (and since the volume is quite small
you round it t zero)
- In order that I can't remove points, How Can I say to CGAL
THEY ARE NOT.
If you can compute another triangulation, but it will not be the
Delaunay triangulation.
- I will use the resultant triangulation in other software where
the jacobian is computed and I can't use the CGAL library. Is
possible to change the CGAL test of coplanar points when the
triangulation is computed?
if you cannot remove points, may be you can add (e.g. using the
meshing package).
Olivier
https://lists-sop.inria.fr/__wws/info/cgal-discuss
<https://lists-sop.inria.fr/wws/info/cgal-discuss>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Gmpq.h>
#include <iostream>
int main(){
  double p1x = 0.00000000000000000;
  double p1y = 0.20000000000000001;
  double p1z = 0.00000000000000000;
  double p2x = 0.20000000000000001;
  double p2y = 0.20000000000000001;
  double p2z = 0.20000000000000001;
  double p3x = 0.40000000000000002;
  double p3y = 0.80000000000000004;
  double p3z = 1.00000000000000000;
  double p4x = 0.20000000000000001;
  double p4y = 0.40000000000000002;
  double p4z = 0.40000000000000002;
  double inexact_jacobian = (p2x - p1x) * (p3y - p1y) * (p4z - p1z) + (p3x - p1x) * (p4y - p1y) * (p2z - p1z) + (p4x - p1x) * (p2y - p1y) * (p3z - p1z) - (p4x - p1x) * (p3y - p1y) * (p2z - p1z) - (p3x - p1x) * (p2y - p1y) * (p4z - p1z) - (p2x - p1x) * (p4y - p1y) * (p3z - p1z);
  CGAL::Gmpq  exact_jacobian = (CGAL::Gmpq(p2x) - CGAL::Gmpq(p1x)) * (CGAL::Gmpq(p3y) - CGAL::Gmpq(p1y)) * (CGAL::Gmpq(p4z) - CGAL::Gmpq(p1z)) + (CGAL::Gmpq(p3x) - CGAL::Gmpq(p1x)) * (CGAL::Gmpq(p4y) - CGAL::Gmpq(p1y)) * (CGAL::Gmpq(p2z) - CGAL::Gmpq(p1z)) + (CGAL::Gmpq(p4x) - CGAL::Gmpq(p1x)) * (CGAL::Gmpq(p2y) - CGAL::Gmpq(p1y)) * (CGAL::Gmpq(p3z) - CGAL::Gmpq(p1z)) - (CGAL::Gmpq(p4x) - CGAL::Gmpq(p1x)) * (CGAL::Gmpq(p3y) - CGAL::Gmpq(p1y)) * (CGAL::Gmpq(p2z) - CGAL::Gmpq(p1z)) - (CGAL::Gmpq(p3x) - CGAL::Gmpq(p1x)) * (CGAL::Gmpq(p2y) - CGAL::Gmpq(p1y)) * (CGAL::Gmpq(p4z) - CGAL::Gmpq(p1z)) - (CGAL::Gmpq(p2x) - CGAL::Gmpq(p1x)) * (CGAL::Gmpq(p4y) - CGAL::Gmpq(p1y)) * (CGAL::Gmpq(p3z) - CGAL::Gmpq(p1z));
  std::cout << "double "<< CGAL::sign(inexact_jacobian) << std::endl;
  std::cout << "Gmpq " << CGAL::sign(exact_jacobian) << std::endl;
