cgal-discuss - Re: [cgal-discuss] concrete example of coplanar points
  • To:
  • Subject: Re: [cgal-discuss] concrete example of coplanar points
  • Date: Fri, 20 Jan 2012 11:32:29 +0100
Le 1/20/12 11:13 AM, Juan Carlos Lopez Alfonso a écrit :
Hi There:
I have this concrete example:
- How is possible that in CGAL these points are not coplanar? because these points are coplanar.
as already explained your points ARE NOT coplanar,
they are just almost coplanar (and since the volume is quite small you round it t zero)
- In order that I can't remove points, How Can I say to CGAL when computes the triangualtion that these points are coplanar?
THEY ARE NOT.
If you can compute another triangulation, but it will not be the Delaunay triangulation.
- I will use the resultant triangulation in other software where the jacobian is computed and I can't use the CGAL library. Is possible to change the CGAL test of coplanar points when the triangulation is computed?
if you cannot remove points, may be you can add (e.g. using the meshing package).
Olivier
