- To:
- Subject: Re: [cgal-discuss] good or bad triangulations?
- Date: Mon, 23 Jan 2012 11:12:14 +0100 (CET)
On Mon, 23 Jan 2012, Juan Carlos Lopez Alfonso wrote:
HiĀ Sebastien:
About your question: The points of an almost coplanar thetraedra are not in
plane with axis aligned normal vectors. In one of my emails, I sent a real
example of a resultant thetraedra, where the points of its vertices are
almost coplanar when I use the coplanar test of CGAL:
p1x = 0.00000000000000000;
p1y = 0.20000000000000001;
p1z = 0.00000000000000000;
p2x = 0.20000000000000001;
p2y = 0.20000000000000001;
p2z = 0.20000000000000001;
p3x = 0.40000000000000002;
p3y = 0.80000000000000004;
p3z = 1.00000000000000000;
p4x = 0.20000000000000001;
p4y = 0.40000000000000002;
p4z = 0.40000000000000002;
I don't know where your coordinates are coming from, but assuming they are all of the form: some integer / 10, it would be preferable to work with the integers directly instead of scaling by 10 (which introduces rounding errors).
Marc Glisse
- [cgal-discuss] good or bad triangulations?, Juan Carlos Lopez Alfonso, 01/23/2012
- Re: [cgal-discuss] good or bad triangulations?, Sebastien Loriot (GeometryFactory), 01/23/2012
- Re: [cgal-discuss] good or bad triangulations?, Juan Carlos Lopez Alfonso, 01/23/2012
- Re: [cgal-discuss] good or bad triangulations?, Monique Teillaud, 01/23/2012
- Re: [cgal-discuss] good or bad triangulations?, Marc Glisse, 01/23/2012
- Re: [cgal-discuss] good or bad triangulations?, Daniel Duque, 01/23/2012
- Re: Re: [cgal-discuss] good or bad triangulations?, Laurent Rineau (GeometryFactory), 01/23/2012
