cgal-discuss - Re: [cgal-discuss] good or bad triangulations?
  • To:
  • Subject: Re: [cgal-discuss] good or bad triangulations?
  • Date: Mon, 23 Jan 2012 12:58:37 +0100
Le 23/01/12 11:38, Laurent Rineau (GeometryFactory) a écrit :
Le lundi 23 janvier 2012 09:48:05 Monique Teillaud a écrit :
Dear Juan Carlos,
You can use another library, it will not change the Delaunay
triangulation. The Delaunay triangulation is known to have slivers, i.e.
tetrahedra whose vertices are almost coplanar and cocircular. As long as
they have an empty circumscribing sphere, they are Delaunay tetrahedra.
There is a huge literature on this topic.
In a Delaunay triangulation you can have every all types of almost degenerate
tetrahedra, not only slivers.
You may want to use another triangulation. The regular triangulation, or
weighted Delaunay triangulation, allows to avoid slivers. So, you can
probably use the CGAL 3D Regular Triangulation, but you will need to
choose the weights of your points in an appropriate way.
There is in particular a paper by Dey, Edelsbrunner and others about
this method (I don't have time right now to dig for the precise reference).
@inproceedings{cdeft-se-99
, author = "Siu-Wing Cheng and Tamal K. Dey and Herbert
Edelsbrunner and Michael A. Facello and Shang-Hua Teng"
, title = "Sliver Exudation"
, booktitle = "Proc. 15th Annu. Sympos. Comput. Geom."
, year = 1999
, pages = "1--13"
@article{cdeft-se-00
, journal = "J. ACM"
, volume = 47
, year = 2000
, pages = "883--904"
In fact this method is already coded in the 3D CGAL mesh package as one
of the optimization methods to improve dihedral angles, you might be
able to reuse some code from this method.
Those optimization methods have been designed to work on regular
triangulations that are made by the mesh generator that does Delaunay
refinement. Those special triangulations are known to have no almost
degenerate tetrahedra but slivers. That is a special case of Delaunay
triangulations. I cannot certify that those optimization methods can do
anything useful on other triangulations.
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
