cgal-discuss - Re: [cgal-discuss] Re: Mesh generation question
  • To:
  • Subject: Re: [cgal-discuss] Re: Mesh generation question
  • Date: Fri, 27 Jan 2012 15:19:03 +0100
Le jeudi 26 janvier 2012 09:43:31 Ram a écrit :
> Hi Laurent,
> Here is the relevant code:
> // Mesh refinement
> CGAL::refine_mesh_3(c3t3, domain, new_criteria);
> // Output
> std::ofstream medit_file("out.mesh");
> c3t3.output_to_medit(medit_file);
> Then i render it using medit, and medit shows me (Right click -> Render
> mode -> Shading)
> http://cgal-discuss.949826.n4.nabble.com/file/n4331141/Capture.jpg
> My rendering, which i posted has similar problems. Lets first fix the
> output_to_medit function (unless I'm doing something wrong), then I can see
> if my code needs fixing?
You are right. Your results are highly surprising. Can you give me the full code, with what you put in 'domain' and in 'new_criteria'? There must be something really wrong, because it seems you just mesh simple cuboid.
Laurent Rineau, PhD
