- To:
- Subject: Re: [cgal-discuss] 2D contour skeletonization
- Date: Wed, 8 Feb 2012 17:00:11 -0500
On Wed, Feb 8, 2012 at 4:48 PM, Qianqian Fang <> wrote:
On 02/06/2012 03:17 AM, Sebastien Loriot (GeometryFactory) wrote:hi Sebastien
If your contours are polygonal, then you can use the
straight skeleton package:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Straight_skeleton_2/Chapter_main.html
thanks for your reply. Unfortunately the contours are
defined by B-splines (but fortunately,, my results do
not require scientific rigor).
I managed to convert the contours to bitmaps and
use other free software to extract the skeleton:
http://tech.groups.yahoo.com/group/autotrace/message/1215
the results is not perfect. I might need to come up
with some post-processing to straighten the lines.
I suspect that you'll get better results if you simply flatten your B-splines into polygons and hand those to Straight_skeleton_2.
Marc.
- [cgal-discuss] 2D contour skeletonization, Qianqian Fang, 02/04/2012
- Re: [cgal-discuss] 2D contour skeletonization, Sebastien Loriot (GeometryFactory), 02/06/2012
- Re: [cgal-discuss] 2D contour skeletonization, Qianqian Fang, 02/08/2012
- Re: [cgal-discuss] 2D contour skeletonization, Marc Downie, 02/08/2012
