- To: Qianqian Fang <>
- Cc:
- Subject: Re: [cgal-discuss] 2D contour skeletonization
- Date: Wed, 8 Feb 2012 17:37:39 -0500
On Wed, Feb 8, 2012 at 5:20 PM, Qianqian Fang <> wrote:
On 02/08/2012 05:00 PM, Marc Downie wrote:hi Marc
I suspect that you'll get better results if you simply flatten your B-splines into polygons and hand those to Straight_skeleton_2.
From the online documents, it appears that a straight skeleton
generates line segments connecting to corners, which are not
desired in my case. Did I understand it correct?
You did. For my applications, I often filter out edges that connect interior points to contours. You probably want to take a good look at section 23.5 of CGAL's manual.
Marc.
- [cgal-discuss] 2D contour skeletonization, Qianqian Fang, 02/04/2012
- Re: [cgal-discuss] 2D contour skeletonization, Sebastien Loriot (GeometryFactory), 02/06/2012
- Re: [cgal-discuss] 2D contour skeletonization, Qianqian Fang, 02/08/2012
- Re: [cgal-discuss] 2D contour skeletonization, Marc Downie, 02/08/2012
