- To:
- Subject: Re: [cgal-discuss] CMake QT4 Building Demos
- Date: Thu, 23 Feb 2012 11:38:33 +0100
Le jeudi 23 février 2012 00:20:10 Julian Hodgson a écrit :
> I'm running cmake-gui in C:/Program Files (x86)/CGAL-3.9/
Don't!
C:/Program Files and C:/Program Files (x86) are special directories on
Windows, where only installers run by the administrator are supposed to be
able to write.
In CMake-GUI, choose C:/Program Files (x86)/CGAL-3.9/ as the source
directory,
but a *user directory* as the binary directory.
What is more, even if you would have the bad (stupid?) idea to run cmake-gui
as the administrator, the parenthesis in the name of "C:/Program Files (x86)"
cause a bug in some macros of CMake, and that may also explain why you have
an
unpredictable behavior of CMake.
Laurent Rineau, PhD
- [cgal-discuss] CMake QT4 Building Demos, Julian Hodgson, 02/23/2012
- Re: [cgal-discuss] CMake QT4 Building Demos, Laurent Rineau (GeometryFactory), 02/23/2012
- Re: [cgal-discuss] CMake QT4 Building Demos, Julian Hodgson, 02/24/2012
- Re: [cgal-discuss] CMake QT4 Building Demos, Sebastien Loriot (GeometryFactory), 02/24/2012
