- To:
- Subject: Re: [cgal-discuss] CMake QT4 Building Demos
- Date: Fri, 24 Feb 2012 17:21:21 +0100
On 02/24/2012 05:14 PM, Julian Hodgson wrote:
Ok that makes sense and now I'm trying to build to C:/CGAL-3.9Since few errors are now gone what is the error you have now?
So now (without admin privileges stupid mistake):
*configure *works with default settings /and /with WITH_examples but
/still fails /with WITH_demos, (see output in my previous email).
It does work when I install CGal in
C:/Program Files
instead of
C:/Program Files (x86)
so you're right about the parentheses - but it happens even with user
privileges
As a suggestion maybe you could change the default installation path of
the installer as workaround?
Best,
Julian
Sebastien.
- [cgal-discuss] CMake QT4 Building Demos, Julian Hodgson, 02/23/2012
- Re: [cgal-discuss] CMake QT4 Building Demos, Laurent Rineau (GeometryFactory), 02/23/2012
- Re: [cgal-discuss] CMake QT4 Building Demos, Julian Hodgson, 02/24/2012
- Re: [cgal-discuss] CMake QT4 Building Demos, Sebastien Loriot (GeometryFactory), 02/24/2012
