- To:
- Subject: Re: [cgal-discuss] CMake QT4 Building Demos
- Date: Fri, 24 Feb 2012 16:14:31 +0000
- Authentication-results: mr.google.com; spf=pass (google.com: domain of designates 10.50.85.227 as permitted sender) ; dkim=pass
Ok that makes sense and now I'm trying to build to C:/CGAL-3.9
So now (without admin privileges stupid mistake):
configure works with default settings and with WITH_examples but still fails with WITH_demos, (see output in my previous email).
It does work when I install CGal in
C:/Program Files
instead of
C:/Program Files (x86)
so you're right about the parentheses - but it happens even with user privileges
As a suggestion maybe you could change the default installation path of the installer as workaround?
Best,
Julian
- [cgal-discuss] CMake QT4 Building Demos, Julian Hodgson, 02/23/2012
- Re: [cgal-discuss] CMake QT4 Building Demos, Laurent Rineau (GeometryFactory), 02/23/2012
- Re: [cgal-discuss] CMake QT4 Building Demos, Julian Hodgson, 02/24/2012
- Re: [cgal-discuss] CMake QT4 Building Demos, Sebastien Loriot (GeometryFactory), 02/24/2012
