cgal-discuss - Re: [cgal-discuss] CMake QT4 Building Demos
  • To:
  • Subject: Re: [cgal-discuss] CMake QT4 Building Demos
  • Date: Fri, 24 Feb 2012 17:17:54 +0100
On 02/24/2012 05:14 PM, Julian Hodgson wrote:
Ok that makes sense and now I'm trying to build to C:/CGAL-3.9
So now (without admin privileges stupid mistake):
*configure *works with default settings /and /with WITH_examples but
/still fails /with WITH_demos, (see output in my previous email).
It does work when I install CGal in
C:/Program Files
instead of
C:/Program Files (x86)
so you're right about the parentheses - but it happens even with user
privileges
As a suggestion maybe you could change the default installation path of
the installer as workaround?
This can be done in the polyhedron demo.
For the code see:
CGAL-X.X/demo/Polyhedron/Polyhedron_demo_triangulate_facets_plugin.cpp
Sebastien.
Best,
Julian
