cgal-discuss - Re: [cgal-discuss] New to CGAL
  • To:
  • Subject: Re: [cgal-discuss] New to CGAL
  • Date: Mon, 27 Feb 2012 16:37:32 +0300
  • Authentication-results: mr.google.com; spf=pass (google.com: domain of designates 10.182.74.102 as permitted sender) ; dkim=pass
Thanks again for this. I need to use CGAL with Microsoft Visual Studio 2010-> any idea how?? thanks again
On 27 February 2012 16:19, Sebastien Loriot (GeometryFactory) <> wrote:
On 02/27/2012 01:34 PM, Sweety Pie wrote:
Thank you very much fr the reply. If you don't have something that reads
.ply files then what file format does CGAL read in terms of point cloud
files??
Thank again and waiting for your reply
CGAL is not a end-user software that accepts a certain type of files,
it's a library that has an API. For the case of the surface
reconstruction  package you need to provide points and normals as
documented here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3_ref/Class_Poisson_reconstruction_function.html
The way you read points and normal from file is independent from the
algorithm (and simple to write for a file of point and normal whatever
file format you use).
Now if you want to try the demo, you can provide off files
or xyz file
which simply contains points if you don't know normals
x0 y0 z0
x1 y1 z1
xn yn zn)
or a pwn file
(which simply contains points and normals
x0 y0 z0 nx0 ny1 nz1
Sebastien.
On 27 February 2012 09:47, Sebastien Loriot (GeometryFactory)
< <mailto:>> wrote:
   On 02/25/2012 08:49 PM, Sweety Pie wrote:
       Hi,
       Am new to CGAL Library and the documentation is very big and
       difficult
       to follow. I wanted to ask if someone can guide me how to read
       .ply file
       since I want to use CGAL to convert point cloud to mesh
       triangles. Any
       help or guide will be appreciated. Am using Microsoft visual
       studio 2010
       with win x64 bit OS.
       Thank you
       Candy
   You might be interested by this package:
   http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Surface_reconstruction_points___3/Chapter_main.html
   <http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html>
   For the  ply file format I don't think we have something to read them.
   Sebastien.
   https://lists-sop.inria.fr/__wws/info/cgal-discuss
   <https://lists-sop.inria.fr/wws/info/cgal-discuss>
