- To:
- Subject: Re: [cgal-discuss] New to CGAL
- Date: Mon, 27 Feb 2012 14:55:31 +0100
What about reading the manual?
www.cgal.org/Pkg/Installation
andreas
On 27/02/2012 14:37, Sweety Pie wrote:
Thanks again for this. I need to use CGAL with Microsoft Visual Studio
2010-> any idea how?? thanks again
On 27 February 2012 16:19, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
On 02/27/2012 01:34 PM, Sweety Pie wrote:
Thank you very much fr the reply. If you don't have something
that reads
.ply files then what file format does CGAL read in terms of
point cloud
files??
Thank again and waiting for your reply
CGAL is not a end-user software that accepts a certain type of files,
it's a library that has an API. For the case of the surface
reconstruction package you need to provide points and normals as
documented here:
http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Surface_reconstruction_points___3_ref/Class_Poisson___reconstruction_function.html
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3_ref/Class_Poisson_reconstruction_function.html>
The way you read points and normal from file is independent from the
algorithm (and simple to write for a file of point and normal whatever
file format you use).
Now if you want to try the demo, you can provide off files
or xyz file
which simply contains points if you don't know normals
x0 y0 z0
x1 y1 z1
xn yn zn)
or a pwn file
(which simply contains points and normals
x0 y0 z0 nx0 ny1 nz1
Sebastien.
On 27 February 2012 09:47, Sebastien Loriot (GeometryFactory)
<mailto:>
<mailto:
<mailto:>>>
wrote:
On 02/25/2012 08:49 PM, Sweety Pie wrote:
Hi,
Am new to CGAL Library and the documentation is very big and
difficult
to follow. I wanted to ask if someone can guide me how
to read
.ply file
since I want to use CGAL to convert point cloud to mesh
triangles. Any
help or guide will be appreciated. Am using Microsoft visual
studio 2010
with win x64 bit OS.
Thank you
Candy
You might be interested by this package:
http://www.cgal.org/Manual/____latest/doc_html/cgal_manual/____Surface_reconstruction_points_____3/Chapter_main.html
<http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Surface_reconstruction_points___3/Chapter_main.html>
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html>>
For the ply file format I don't think we have something to
read them.
Sebastien.
https://lists-sop.inria.fr/____wws/info/cgal-discuss
<https://lists-sop.inria.fr/__wws/info/cgal-discuss>
<https://lists-sop.inria.fr/wws/info/cgal-discuss>>
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] New to CGAL, Sweety Pie, 02/25/2012
- Re: [cgal-discuss] New to CGAL, Sebastien Loriot (GeometryFactory), 02/27/2012
- Re: [cgal-discuss] New to CGAL, Sweety Pie, 02/27/2012
- Re: [cgal-discuss] New to CGAL, Andreas Fabri, 02/27/2012
- Re: [cgal-discuss] New to CGAL, Philipp Moeller, 02/27/2012
- Re: [cgal-discuss] New to CGAL, Clément Jamin, 02/27/2012
