cgal-discuss - Re: [cgal-discuss] New to CGAL
  • To:
  • Subject: Re: [cgal-discuss] New to CGAL
  • Date: Mon, 27 Feb 2012 19:25:41 +0300
  • Authentication-results: mr.google.com; spf=pass (google.com: domain of designates 10.182.31.47 as permitted sender) ; dkim=pass
Thank you very much for this. It is really appreciated. Will try all of these and will let you know if any problem occurred then. Thanks again to all.
On 27 February 2012 18:19, Philipp Moeller <> wrote:
This should get you started to read a PLY file into a Polyhedron using
RPly [1] and CGAL::Incremental_builder_3 [2]
It requires ply files with the following structure:
- a "vertex" element has the properties "x", "y", and "z" specifying its coordinates
- a "face" element has a property list "index_vertices" specifying the
 indices of the face
The program itself reads from a ply file and writes to an off file.
It hasn't been extensively tested and I'm not much of a C programmer. If
it breaks you get to keep both pieces ;)
[1] : http://w3.impa.br/~diego/software/rply/#ply_get_next_element
[2] : http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_incremental_builder_3.html
HTH,
Philipp
Sweety Pie <> writes:
> Thank you very much fr the reply. If you don't have something that reads
> .ply files then what file format does CGAL read in terms of point cloud
> files??
> Thank again and waiting for your reply
> On 27 February 2012 09:47, Sebastien Loriot (GeometryFactory) <
> > wrote:
>> On 02/25/2012 08:49 PM, Sweety Pie wrote:
>>> Hi,
>>> Am new to CGAL Library and the documentation is very big and difficult
>>> to follow. I wanted to ask if someone can guide me how to read .ply file
>>> since I want to use CGAL to convert point cloud to mesh triangles. Any
>>> help or guide will be appreciated. Am using Microsoft visual studio 2010
>>> with win x64 bit OS.
>>> Thank you
>>> Candy
>> You might be interested by this package:
>> http://www.cgal.org/Manual/**latest/doc_html/cgal_manual/**
>> Surface_reconstruction_points_**3/Chapter_main.html<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html>
>> For the  ply file format I don't think we have something to read them.
>> Sebastien.
>> https://lists-sop.inria.fr/**wws/info/cgal-discuss<https://lists-sop.inria.fr/wws/info/cgal-discuss>
