cgal-discuss - Re: [cgal-discuss] New to CGAL
  • To:
  • Subject: Re: [cgal-discuss] New to CGAL
  • Date: Mon, 27 Feb 2012 16:19:24 +0100
This should get you started to read a PLY file into a Polyhedron using
RPly [1] and CGAL::Incremental_builder_3 [2]
It requires ply files with the following structure:
- a "vertex" element has the properties "x", "y", and "z" specifying its
coordinates
- a "face" element has a property list "index_vertices" specifying the
indices of the face
The program itself reads from a ply file and writes to an off file.
It hasn't been extensively tested and I'm not much of a C programmer. If
it breaks you get to keep both pieces ;)
[1] : http://w3.impa.br/~diego/software/rply/#ply_get_next_element
[2] :
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_incremental_builder_3.html
Attachment: CGALply.zip
Description: CGALply example with incremental builder
HTH,
Philipp
Sweety Pie
writes:
> Thank you very much fr the reply. If you don't have something that reads
> .ply files then what file format does CGAL read in terms of point cloud
> files??
> Thank again and waiting for your reply
> On 27 February 2012 09:47, Sebastien Loriot (GeometryFactory) <
> wrote:
>> On 02/25/2012 08:49 PM, Sweety Pie wrote:
>>> Hi,
>>> Am new to CGAL Library and the documentation is very big and difficult
>>> to follow. I wanted to ask if someone can guide me how to read .ply file
>>> since I want to use CGAL to convert point cloud to mesh triangles. Any
>>> help or guide will be appreciated. Am using Microsoft visual studio 2010
>>> with win x64 bit OS.
>>> Thank you
>>> Candy
>> You might be interested by this package:
>> http://www.cgal.org/Manual/**latest/doc_html/cgal_manual/**
>> Surface_reconstruction_points_**3/Chapter_main.html<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html>
>> For the ply file format I don't think we have something to read them.
>> Sebastien.
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/**wws/info/cgal-discuss<https://lists-sop.inria.fr/wws/info/cgal-discuss>
