Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h
- To:
- Subject: Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h
- Date: Fri, 2 Mar 2012 19:48:25 +0800
- Authentication-results: mr.google.com; spf=pass (google.com: domain of designates 10.112.86.229 as permitted sender) ; dkim=pass
On 2 March 2012 18:51, Sebastien Loriot (GeometryFactory)
wrote:
> Maybe another optimization problem.
> Can you provide a minimal example showing the problem?
> Sebastien.
> On 03/02/2012 11:32 AM, Nicholas Mario Wardhana wrote:
>> Dear all,
>> Given an input point in 3D space, I am trying to find the closest
>> point in a list of thousands to tens of thousands of points. However,
>> I often got the following assertion error.
>> CGAL error: assertion violation!
>> Expression : new_rd>= copy_rd
>> File : D:\nixx\Documents\Visual Studio
>> 2008\Projects\Testbed\dependencies\
>> CGAL-3.9\include\CGAL/Orthogonal_incremental_neighbor_search.h
>> Line : 267
>> Explanation:
>> Refer to the bug-reporting instructions at
>> http://www.cgal.org/bug_report.html
>> Sometimes the error is in line 288 instead. I am wondering if somebody
>> can give me a clue about what causes this error? The list of points is
>> generated from a preceding algorithm, so I suspect there were some
>> mistakes in it.
>> The strange thing is that results might vary in Debug and Release
>> configurations. There was one time when I wanted to debug the code by
>> inputting the point which previously gave error, but it turned out
>> that no error was produced.
>> I found this thread:
>> http://cgal-discuss.949826.n4.nabble.com/Spatial-Searching-How-to-cope-with-duplicate-points-td3002341.html
>> but the patch posted by Dr Loriot there does not work for me, as it
>> caused some tens to hundreds of compilation errors. I also suppose
>> that there is no duplicate point in the list.
>> I use CGAL 3.9 and Boost 1.48, and compile my code using Visual Studio
>> 2008 on both Windows Vista and Windows 7. Please let me know if I need
>> to give more information.
>> By the way, I am presently upgrading the Boost library, and afterwards
>> I will rebuild CGAL rebuild my project again, so I will see whether
>> there will still be an error after this.
>> Thank you very much!
>> Best regards,
>> Nicholas
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Thank you very much for your quick reply, Dr. Loriot!
As for the minimum example, let's see if I can do it, as the error
seems to depend on the list of points. Previously, I tested with 1000
collinear points along z axis (that is, (0, 0, 0) to (0, 0, 1000),
with a distance of 1 for every pair of nearby points), and it was
fine. I will try to generate a new list of points which is small
enough to be hard-coded.
For now, I can give the following snippet.
// ---------------- Snippet starts here ----------------
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Point_3<Kernel> Point;
typedef CGAL::Search_traits<double, CGAL3DPointNNS<NNSData>, const
double*, ConstructCoordIterator<NNSData>> TreeTraits;
typedef CGAL::Orthogonal_incremental_neighbor_search<TreeTraits,
NNSDistance<NNSData>> NeighbourSearch;
typedef typename NeighbourSearch::Tree Tree;
CGAL3DPointNNS<NNSData> query = CGAL3DPointNNS<NNSData>(rkInput.x,
rkInput.y, rkInput.z, NNSData());
Tree tree(m_pointList.begin(), m_pointList.end());
NeighbourSearch search(tree, query);
rSortedNeighbourList.clear();
rDataList.clear();
rSquaredDistanceList.clear();
for(NeighbourSearch::iterator neighbourIterator = search.begin();
neighbourIterator != search.end();
neighbourIterator++)
// Assertion violation happens somewhere in this loop!
Vec3 point(neighbourIterator->first.x(),
neighbourIterator->first.y(), neighbourIterator->first.z());
rSortedNeighbourList.push_back(point);
rDataList.push_back(neighbourIterator->first.data);
rSquaredDistanceList.push_back(neighbourIterator->second);
// ---------------- Snippet ends here ----------------
Some explanations about the classes and variables:
- CGAL3DPointNNS is based on the class Point in
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html#Subsection_60.3.5
- NNSData is a data class which I embed in every point in the space
- Vec3 is our implementation of point in 3D space
- m_pointList is the list of points
- rkInput is the input point, whose closest point in m_pointList is to be
found
- rSortedNeighbourList is an output parameter to store the list of
points, sorted by distance to rkInput
- rDataList is the similarly sorted list of NNSData variables
- rSquaredDistanceList is the similarly sorted list of squared
distance of points in rSortedNeighbourList
The error comes up when I iterate through the for loop. Unfortunately,
as I mentioned in my previous e-mail, for some random points which I
input manually, it didn't give any error when I debugged the code in
Debug configuration.
Thank you!
Best regards,
Nicholas
- [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Nicholas Mario Wardhana, 03/02/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Sebastien Loriot (GeometryFactory), 03/02/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Nicholas Mario Wardhana, 03/02/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Nicholas Mario Wardhana, 03/06/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Sebastien Loriot (GeometryFactory), 03/06/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Nicholas Mario Wardhana, 03/07/2012
