cgal-discuss - Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h
  • To:
  • Subject: Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h
  • Date: Fri, 2 Mar 2012 20:18:03 +0800
  • Authentication-results: mr.google.com; spf=pass (google.com: domain of designates 10.152.122.74 as permitted sender) ; dkim=pass
On 2 March 2012 19:48, Nicholas Mario Wardhana
wrote:
> On 2 March 2012 18:51, Sebastien Loriot (GeometryFactory)
> wrote:
>> Maybe another optimization problem.
>> Can you provide a minimal example showing the problem?
>> Sebastien.
> Thank you very much for your quick reply, Dr. Loriot!
> As for the minimum example, let's see if I can do it, as the error
> seems to depend on the list of points. Previously, I tested with 1000
> collinear points along z axis (that is, (0, 0, 0) to (0, 0, 1000),
> with a distance of 1 for every pair of nearby points), and it was
> fine. I will try to generate a new list of points which is small
> enough to be hard-coded.
> For now, I can give the following snippet.
> // ---------------- Snippet starts here ----------------
> typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
> typedef CGAL::Point_3<Kernel>  Point;
> typedef CGAL::Search_traits<double, CGAL3DPointNNS<NNSData>, const
> double*, ConstructCoordIterator<NNSData>> TreeTraits;
> typedef CGAL::Orthogonal_incremental_neighbor_search<TreeTraits,
> NNSDistance<NNSData>> NeighbourSearch;
> typedef typename NeighbourSearch::Tree Tree;
> CGAL3DPointNNS<NNSData> query = CGAL3DPointNNS<NNSData>(rkInput.x,
> rkInput.y, rkInput.z, NNSData());
> Tree tree(m_pointList.begin(), m_pointList.end());
> NeighbourSearch search(tree, query);
> rSortedNeighbourList.clear();
> rDataList.clear();
> rSquaredDistanceList.clear();
> for(NeighbourSearch::iterator neighbourIterator = search.begin();
>        neighbourIterator != search.end();
>        neighbourIterator++)
>        // Assertion violation happens somewhere in this loop!
>        Vec3 point(neighbourIterator->first.x(),
> neighbourIterator->first.y(), neighbourIterator->first.z());
>        rSortedNeighbourList.push_back(point);
>        rDataList.push_back(neighbourIterator->first.data);
>        rSquaredDistanceList.push_back(neighbourIterator->second);
> // ---------------- Snippet ends here ----------------
> Some explanations about the classes and variables:
> - CGAL3DPointNNS is based on the class Point in
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html#Subsection_60.3.5
> - NNSData is a data class which I embed in every point in the space
> - Vec3 is our implementation of point in 3D space
> - m_pointList is the list of points
> - rkInput is the input point, whose closest point in m_pointList is to be
> found
> - rSortedNeighbourList is an output parameter to store the list of
> points, sorted by distance to rkInput
> - rDataList is the similarly sorted list of NNSData variables
> - rSquaredDistanceList is the similarly sorted list of squared
> distance of points in rSortedNeighbourList
> The error comes up when I iterate through the for loop. Unfortunately,
> as I mentioned in my previous e-mail, for some random points which I
> input manually, it didn't give any error when I debugged the code in
> Debug configuration.
> Thank you!
> Best regards,
> Nicholas
To be more exact, the problem arises when incrementing
neighbourIterator (neighbourIterator++).
Best regards,
Nicholas
