Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h
- To:
- Subject: Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h
- Date: Tue, 06 Mar 2012 18:29:02 +0100
Let switch the discussion in private. I'll post the answer on this list if we find a solution.
On 03/06/2012 06:08 PM, Nicholas Mario Wardhana wrote:
On 7 March 2012 00:33, Sebastien Loriot (GeometryFactory)
wrote:
Thanks for the update.
Can you try before the assertion
CGAL_assertion(new_rd>= copy_rd);
to change
new_rd=Orthogonal_distance_instance.new_distance(copy_rd,old_off,new_off,new_cut_dim);
into
new_rd=old_off==new_off?copy_rd:Orthogonal_distance_instance.new_distance(copy_rd,old_off,new_off,new_cut_dim);
I still suspect an optimization problem.
Sebastien.
Hi Dr Loriot,
After reverting to the previous assertions and changing the lines as
you suggested, I still got the same error. For example, in one
occasion, I got the following values:
new_rd = 3240.3969698751616
copy_rd = 3240.3969698751621 ,
so I suppose it was still the same floating point problem. Anyway, I
am wondering if you mind telling me a bit about what that new line
does?
Thank you.
Best regards,
Nicholas
- [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Nicholas Mario Wardhana, 03/02/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Sebastien Loriot (GeometryFactory), 03/02/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Nicholas Mario Wardhana, 03/02/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Nicholas Mario Wardhana, 03/06/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Sebastien Loriot (GeometryFactory), 03/06/2012
- Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h, Nicholas Mario Wardhana, 03/07/2012
