cgal-discuss - Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h
  • To:
  • Subject: Re: [cgal-discuss] "new_rd >= copy_rd" assertion violation in Orthogonal_incremental_neighbor_search.h
  • Date: Wed, 7 Mar 2012 01:08:35 +0800
  • Authentication-results: mr.google.com; spf=pass (google.com: domain of designates 10.152.128.163 as permitted sender) ; dkim=pass
On 7 March 2012 00:33, Sebastien Loriot (GeometryFactory)
wrote:
> Thanks for the update.
> Can you try before the assertion
> CGAL_assertion(new_rd >= copy_rd);
> to change
> new_rd=Orthogonal_distance_instance.new_distance(copy_rd,old_off,new_off,new_cut_dim);
> into
> new_rd=old_off==new_off?copy_rd:Orthogonal_distance_instance.new_distance(copy_rd,old_off,new_off,new_cut_dim);
> I still suspect an optimization problem.
> Sebastien.
Hi Dr Loriot,
After reverting to the previous assertions and changing the lines as
you suggested, I still got the same error. For example, in one
occasion, I got the following values:
new_rd = 3240.3969698751616
copy_rd = 3240.3969698751621 ,
so I suppose it was still the same floating point problem. Anyway, I
am wondering if you mind telling me a bit about what that new line
does?
Thank you.
Best regards,
Nicholas
