- To:
- Subject: Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl
- Date: Fri, 2 Mar 2012 16:08:19 +0100 (CET)
On Fri, 2 Mar 2012, Zohar wrote:
1. Why is the Simple_Cartesian better than the Cartesian?
I found in the doc of simple_cart:
"In contrast to Cartesian, no reference counting is used internally. This
eases debugging, but may slow down algorithms that copy objects
intensively."
It is not better in general. When the number type is double, the heavy reference counting machinery has only drawbacks (copying a pair of double takes no time): dynamic allocation, thread-unsafe. When the number type is something heavy (say mpq_class or some other bignum that is not already reference-counted) and you do a lot a copying objects around, it can be a life-saver.
Marc Glisse
- [cgal-discuss] Re: Intersecting with Cartesian kerenl, Zohar, 03/02/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Sebastien Loriot (GeometryFactory), 03/02/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Marc Glisse, 03/02/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Stefan Schirra, 03/02/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Philipp Moeller, 03/02/2012
