cgal-discuss - Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl
  • To:
  • Subject: Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl
  • Date: Fri, 02 Mar 2012 16:46:44 +0100
On 02.03.2012 16:08, Marc Glisse wrote:
On Fri, 2 Mar 2012, Zohar wrote:
1. Why is the Simple_Cartesian better than the Cartesian?
I found in the doc of simple_cart:
"In contrast to Cartesian, no reference counting is used internally. This
eases debugging, but may slow down algorithms that copy objects
intensively."
It is not better in general. When the number type is double, the heavy
reference
counting machinery has only drawbacks (copying a pair of double takes no
time):
dynamic allocation, thread-unsafe. When the number type is something heavy
(say
mpq_class or some other bignum that is not already reference-counted) and you
do
a lot a copying objects around, it can be a life-saver.
Sorry Marc, I do not fully agree.
Thread-safety is certainly an issue. However, even copying pairs of doubles takes some time. It is not clear whether it takes more time than copying a pointer and incrementing an int. Even if it would, your application must copy a lot, because of the indirection in the access operations (cache effects are an issue as well). So it depends. For more, probably somewhat outdated, information on this issue, see "S. Schirra; A Case Study on the Cost of Geometric Computing. In Algorithm Engineering and Experimentation (ALENEX99), pages 156-176, 1999. Springer, Berlin. Note: LNCS 1619.
For "heavy number types", you can usually use Simple_cartesian, because mpq_class and other bignum integers already use reference counting themselves! So you don't copy bignums anyway.
--Stefan
