- To:
- Subject: Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl
- Date: Fri, 2 Mar 2012 18:04:23 +0100 (CET)
On Fri, 2 Mar 2012, Stefan Schirra wrote:
On 02.03.2012 16:08, Marc Glisse wrote:
On Fri, 2 Mar 2012, Zohar wrote:
1. Why is the Simple_Cartesian better than the Cartesian?
I found in the doc of simple_cart:
"In contrast to Cartesian, no reference counting is used internally. This
eases debugging, but may slow down algorithms that copy objects
intensively."
It is not better in general. When the number type is double, the heavy reference
counting machinery has only drawbacks (copying a pair of double takes no time):
dynamic allocation, thread-unsafe. When the number type is something heavy (say
mpq_class or some other bignum that is not already reference-counted) and you do
a lot a copying objects around, it can be a life-saver.
Sorry Marc, I do not fully agree.
Well, I agree that we disagree ;-)
Thread-safety is certainly an issue. However, even copying pairs of doubles takes some time.
When the compiler can't detect it is unnecessary (which it often can with double, but not with heavy types).
It is not clear whether it takes more time than copying a pointer and incrementing an int.
Hmm...
Let me cheat a little bit: it would (will?) be even more true with points stored as SSE/AVX vectors.
Even if it would, your application must copy a lot, because of the indirection in the access operations (cache effects are an issue as well).
Yes, indirections make reference-counting slower. Ok, a pointer takes less space than a pair of double, so if you manipulate many points directly (not through a reference) without ever looking at their coordinates, Simple_cartesian can take a tiny bit more cache. On the other hand, it takes a lot less memory and is thus still likely to be more cache efficient.
So it depends. For more, probably somewhat outdated, information on this issue, see "S. Schirra; A Case Study on the Cost of Geometric Computing. In Algorithm Engineering and Experimentation (ALENEX99), pages 156-176, 1999. Springer, Berlin. Note: LNCS 1619.
Cool, your paper agrees that for double, Simple_cartesian is faster than Cartesian (which is all I claimed in my email).
For "heavy number types", you can usually use Simple_cartesian, because mpq_class and other bignum integers already use reference counting themselves! So you don't copy bignums anyway.
I precisely chose mpq_class as an example because it is *NOT* reference-counted. You are confusing it with Gmpq (which wastes a lot of time in memory allocations, but that's a discussion for another day).
Marc Glisse
- [cgal-discuss] Re: Intersecting with Cartesian kerenl, Zohar, 03/02/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Sebastien Loriot (GeometryFactory), 03/02/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Marc Glisse, 03/02/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Stefan Schirra, 03/02/2012
- Re: [cgal-discuss] Re: Intersecting with Cartesian kerenl, Philipp Moeller, 03/02/2012
