cgal-discuss - [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation
  • To:
  • Subject: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation
  • Date: Tue, 6 Mar 2012 07:22:44 -0800 (PST)
hi,
thank you for your reply really rapid.
In fact, my program uses Delaunay triangulation during the whole process
except at the last step, I want to do some local modifications of the
triangulation but without the Delaunay triangulation constraint. That's why
I want to crate a simple triangulation which is copied from the Delaunay and
the local modifications could be done with this new triangulation.
I have tested the tds.swap() but it does not work. In fact, if we have
simple Triangulatio1, Triangulation2, and Delaunay1,Delaunay2. We can have
Triangulation1.tds()=Triangulation2.tds() and
Delaunay1.tds()=Delaunay2.tds(), but never
Triangulation1.tds()=Delaunay1.tds() with CGAL. Note also that in the
typedefs, we use exactly the same Triangulation_data_strcture_3 for both
simple triangulation and Delaunay triangulation.
Do you have any suggestion about my problem? best regards
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Copy-of-Delaunay-triangulation-to-a-simple-Triangulation-tp4450013p4450185.html
