Re: Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation
- To:
- Subject: Re: Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation
- Date: Tue, 06 Mar 2012 16:58:22 +0100
Le mardi 06 mars 2012 16:48:37 Sebastien Loriot a écrit :
> On 03/06/2012 04:22 PM, petitmalin wrote:
> > hi,
> > thank you for your reply really rapid.
> > In fact, my program uses Delaunay triangulation during the whole process
> > except at the last step, I want to do some local modifications of the
> > triangulation but without the Delaunay triangulation constraint. That's
> > why
> > I want to crate a simple triangulation which is copied from the Delaunay
> > and the local modifications could be done with this new triangulation.
> > I have tested the tds.swap() but it does not work. In fact, if we have
> > simple Triangulatio1, Triangulation2, and Delaunay1,Delaunay2. We can
> > have
> > Triangulation1.tds()=Triangulation2.tds() and
> > Delaunay1.tds()=Delaunay2.tds(), but never
> > Triangulation1.tds()=Delaunay1.tds() with CGAL. Note also that in the
> > typedefs, we use exactly the same Triangulation_data_strcture_3 for both
> > simple triangulation and Delaunay triangulation.
> > Do you have any suggestion about my problem? best regards
> Don't really get what you want to do but you might want to do the following:
> Delaunay_triangulation_3 dt1;
> Triangulation_3 t1(dt1);
Or even a downcast:
Triangulation_3& t1 = dt1;
that should be possible because CGAL::Delaunay_triangulation_3<K,
TDS,CGAL::Fast_location> derives from CGAL::Triangulation_3<K,TDS>.
Laurent Rineau, PhD
- [cgal-discuss] Copy of Delaunay triangulation to a simple Triangulation, petitmalin, 03/06/2012
- Re: [cgal-discuss] Copy of Delaunay triangulation to a simple Triangulation, Sebastien Loriot (GeometryFactory), 03/06/2012
- [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, petitmalin, 03/06/2012
- Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Sebastien Loriot (GeometryFactory), 03/06/2012
- Re: Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Laurent Rineau (GeometryFactory), 03/06/2012
- Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Olivier Devillers, 03/06/2012
- [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, petitmalin, 03/07/2012
- Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Sebastien Loriot (GeometryFactory), 03/07/2012
- Re: Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Laurent Rineau (GeometryFactory), 03/07/2012
