Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation
- To:
- Subject: Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation
- Date: Wed, 07 Mar 2012 16:16:55 +0100
Delaunay_triangulation_3<Gt, Tds_> inherits from
Triangulation_3<Gt, Delaunay_triangulation_3<Gt, Tds_>::Triangulation_data_structure>
If you use Fast_location policy, you internally want to use
the triangulation hierarchy which has enriched TDS items
(which why you have errors when Fast_location is here).
Sebastien
On 03/07/2012 02:53 PM, petitmalin wrote:
Ok, thanks for all your helps, I really appreciate them. Now I come here to
close the discussion.
I have solved my problem in a strange way. In fact, I have tried all methods
of conversion from Delaunay_3 to Triangulation_3 that you and your
colleagues proposed (even tried to convert manually vertices() and cells()
of Delaunay_3.tds() to Triangulation_3.tds() ), I got always errors of
compilation. So i tried to modify everywhere of my programme and strangely,
i found that if I comment "CGAL::Fast_location" in
"typedef CGAL::Delaunay_triangulation_3<K, TDS,CGAL::Fast_location>
Delaunay;"
and the problem is solved, no more compilation error exists.
I do not know if this is a bug of CGAL but the solution is that. I wish this
can help other people who met this problem.
best regards
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Copy-of-Delaunay-triangulation-to-a-simple-Triangulation-tp4450013p4453310.html
- [cgal-discuss] Copy of Delaunay triangulation to a simple Triangulation, petitmalin, 03/06/2012
- Re: [cgal-discuss] Copy of Delaunay triangulation to a simple Triangulation, Sebastien Loriot (GeometryFactory), 03/06/2012
- [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, petitmalin, 03/06/2012
- Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Sebastien Loriot (GeometryFactory), 03/06/2012
- Re: Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Laurent Rineau (GeometryFactory), 03/06/2012
- Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Olivier Devillers, 03/06/2012
- [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, petitmalin, 03/07/2012
- Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Sebastien Loriot (GeometryFactory), 03/07/2012
- Re: Re: [cgal-discuss] Re: Copy of Delaunay triangulation to a simple Triangulation, Laurent Rineau (GeometryFactory), 03/07/2012
