cgal-discuss - Re: [cgal-discuss] Re: Triangle_2 intersection throws exception
  • To:
  • Subject: Re: [cgal-discuss] Re: Triangle_2 intersection throws exception
  • Date: Tue, 06 Mar 2012 17:38:56 +0100
Which CGAL version are you using?
Sebastien.
On 03/06/2012 05:24 PM, mriem wrote:
Hi Sebastien
Thanks for the quick repply
I did as you suggest, used a exact_predicates_exact_construnctors kernel
but now I geta warning inside the same function
object_cast inside Lazy_construction_rep::operator() failed. It needs more
else if's (#1)
dynamic type of the Object :
St6vectorIN4CGAL7Point_2INS0_16Simple_cartesianINS0_11Interval_ntILb0EEEEEEESaIS6_EE
which causes my program later on to segfault.
Can you help me?
Miguel
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangle-2-intersection-throws-exception-tp4449736p4450411.html
