- To:
- Subject: Re: [cgal-discuss] Re: Triangle_2 intersection throws exception
- Date: Tue, 06 Mar 2012 17:53:55 +0100
On 03/06/2012 05:58 PM, Miguel Oliveira wrote:
Hi Sebastien
I use linux ubuntu newest version
just installed with sudo apt-get install libcgal*
There are 2 packages
The library itself, says version
libcgal7 3.8-1
the dev files, says version
libcgal-dev 3.8-1
IIRC the bug you encountered has been fixed in CGAL-3.9
Read again the FAQ entry, this is not a good idea to try to do that.
Another question: Since my problem at the begining was an exception in
function
CGAL::intersection(*t0, *t1);
Can I use some kind of try catch scheme to catch the exception?
Sebastien.
Thanks
Miguel
On 03/06/2012 04:38 PM, Sebastien Loriot (GeometryFactory) wrote:
Which CGAL version are you using?
Sebastien.
On 03/06/2012 05:24 PM, mriem wrote:
Hi Sebastien
Thanks for the quick repply
I did as you suggest, used a exact_predicates_exact_construnctors kernel
but now I geta warning inside the same function
object_cast inside Lazy_construction_rep::operator() failed. It needs
more
else if's (#1)
dynamic type of the Object :
St6vectorIN4CGAL7Point_2INS0_16Simple_cartesianINS0_11Interval_ntILb0EEEEEEESaIS6_EE
which causes my program later on to segfault.
Can you help me?
Miguel
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangle-2-intersection-throws-exception-tp4449736p4450411.html
- [cgal-discuss] Triangle_2 intersection throws exception, mriem, 03/06/2012
- Re: [cgal-discuss] Triangle_2 intersection throws exception, Miguel Oliveira, 03/06/2012
- Re: [cgal-discuss] Triangle_2 intersection throws exception, Sebastien Loriot (GeometryFactory), 03/06/2012
- [cgal-discuss] Re: Triangle_2 intersection throws exception, mriem, 03/06/2012
- Re: [cgal-discuss] Re: Triangle_2 intersection throws exception, Sebastien Loriot (GeometryFactory), 03/06/2012
- Re: [cgal-discuss] Re: Triangle_2 intersection throws exception, Miguel Oliveira, 03/06/2012
- [cgal-discuss] Re: Triangle_2 intersection throws exception, mriem, 03/09/2012
