- To:
- Subject: Re: [cgal-discuss] Re: Triangle_2 intersection throws exception
- Date: Tue, 06 Mar 2012 16:58:59 +0000
Hi Sebastien I use linux ubuntu newest version just installed with sudo apt-get install libcgal* There are 2 packages The library itself, says version libcgal7 3.8-1 the dev files, says version libcgal-dev 3.8-1 Another question: Since my problem at the begining was an exception in function CGAL::intersection(*t0, *t1); Can I use some kind of try catch scheme to catch the exception? Thanks Miguel On 03/06/2012 04:38 PM, Sebastien Loriot (GeometryFactory) wrote: Which CGAL version are you using? |
- [cgal-discuss] Triangle_2 intersection throws exception, mriem, 03/06/2012
- Re: [cgal-discuss] Triangle_2 intersection throws exception, Miguel Oliveira, 03/06/2012
- Re: [cgal-discuss] Triangle_2 intersection throws exception, Sebastien Loriot (GeometryFactory), 03/06/2012
- [cgal-discuss] Re: Triangle_2 intersection throws exception, mriem, 03/06/2012
- Re: [cgal-discuss] Re: Triangle_2 intersection throws exception, Sebastien Loriot (GeometryFactory), 03/06/2012
- Re: [cgal-discuss] Re: Triangle_2 intersection throws exception, Miguel Oliveira, 03/06/2012
- [cgal-discuss] Re: Triangle_2 intersection throws exception, mriem, 03/09/2012
