- To:
- Subject: [cgal-discuss] Re: How to use CGAL Trang methods
- Date: Fri, 9 Mar 2012 14:56:42 -0800 (PST)
Generating the VS solutions with cmake is the same method as when you
generated and compiled the CGAL libs.
Paste the folder path for the example you want into "Where is the source
code" and "Where is the binaries" and click Configure, then Generate. Then
open the .sln file in Visual Studio and build. That's how I usually do it
anyway.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-CGAL-Trang-methods-tp4455754p4460930.html
- [cgal-discuss] How to use CGAL Trang methods, Sweety Pie, 03/08/2012
- Re: [cgal-discuss] How to use CGAL Trang methods, Sebastien Loriot (GeometryFactory), 03/08/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, ahmed, 03/08/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/09/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, freckles, 03/09/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/10/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, ayongwust_sjtu, 03/10/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, ayongwust_sjtu, 03/12/2012
- Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/12/2012
- Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
