- To:
- Subject: [cgal-discuss] Re: How to use CGAL Trang methods
- Date: Mon, 12 Mar 2012 03:29:33 -0700 (PDT)
It's a good start.
Please reference below
4.11 Qt
Qt is a cross-platform application and UI framework.
Most Cgal demos use Qt3 or Qt4. Having Qt4 version 4.3.0 or higher is
recommended.
In case Qt is not yet installed on your system, you can download it from
http://qt.nokia.com/.
from
http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Section_1
Regards,
Xianyong Liu
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-use-CGAL-Trang-methods-tp4455754p4465747.html
- [cgal-discuss] How to use CGAL Trang methods, Sweety Pie, 03/08/2012
- Re: [cgal-discuss] How to use CGAL Trang methods, Sebastien Loriot (GeometryFactory), 03/08/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, ahmed, 03/08/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/09/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, freckles, 03/09/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/10/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, ayongwust_sjtu, 03/10/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, ayongwust_sjtu, 03/12/2012
- Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/12/2012
- Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
