- To:
- Subject: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
- Date: Tue, 13 Mar 2012 11:30:57 +0300
Just a small question: Does CMake work with win x64 bit?
On 12 March 2012 21:11, Sweety Pie <> wrote:
The GNU is for the Zlib thing to uncompress the files.I will send you the txt file .Thank you very much for the helpRegards,On 12 March 2012 21:03, Laurent Rineau (GeometryFactory) <> wrote:
Le lundi 12 mars 2012 20:55:40 Sweety Pie a écrit :
> C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\CL.exe /cYou compile using MSVC 2010, 32 bits version. But what is that GnuWin32 stuff
> /I"C:/Program Files (x86)/GnuWin32/include" /Zi /nologo /W3 /WX- /Od /Ob0
> /Oy- /D WIN32 /D _WINDOWS /D _CRT_SECURE_NO_DEPRECATE /D
> _SCL_SECURE_NO_DEPRECATE /D _CRT_SECURE_NO_WARNINGS /D
> _SCL_SECURE_NO_WARNINGS /D _DEBUG /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm-
> /EHsc /RTC1 /MDd /GS /fp:strict /fp:except- /Zc:wchar_t /Zc:forScope /GR
> /Fo"cmTryCompileExec.dir\Debug\\" /Fd"C:/Program Files
> (x86)/CGAL-3.9/CMakeFiles/CMakeTmp/Debug/cmTryCompileExec.pdb" /Gd /TP
> /analyze- /errorReport:queue ..\..\config\support\print_ZLIB_version.cpp
> /Zm1000
and why is it in the include path?
Can you send me the generated CMakeCache.txt privately?
Laurent Rineau, PhD
- [cgal-discuss] Re: How to use CGAL Trang methods, (continued)
- [cgal-discuss] Re: How to use CGAL Trang methods, freckles, 03/09/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/10/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, ayongwust_sjtu, 03/10/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- [cgal-discuss] Re: How to use CGAL Trang methods, ayongwust_sjtu, 03/12/2012
- Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/12/2012
- Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/12/2012
- Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
