- To:
- Subject: Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron
- Date: Thu, 22 Mar 2012 23:24:25 +0100
On 03/20/2012 11:06 PM, Zohar wrote:
I don't get what you meant. Have you read the message I refer to?
Is it the same link that I wrote in my first post, which uses an old
interface and thus doesn't work?
But Sebastien, maybe you know the difference between the c2t3 and c3t3: Read
my first post on
http://cgal-discuss.949826.n4.nabble.com/Surface-remeshing-using-mesh-generation-td4471479.html
See also this:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_3_ref/Concept_MeshComplex_3InTriangulation_3.html
and the iterator range provided by
facets_in_complex_begin(),facets_in_complex_end()
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Convert-C3t3-to-Polyhedron-tp4467182p4490524.html
- [cgal-discuss] Convert C3t3 to Polyhedron, Zohar, 03/12/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/13/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/20/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/20/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/22/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/23/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/23/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/24/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/25/2012
- Re:Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Yan Shijiang, 03/25/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Philipp Moeller, 03/25/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/25/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/26/2012
