- To:
- Subject: Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron
- Date: Fri, 23 Mar 2012 08:33:25 +0100
On 03/23/2012 02:34 AM, Zohar wrote:
Sorry I looked for a link in a previous post but could not find it.
1. This is our current thread:
http://cgal-discuss.949826.n4.nabble.com/Convert-C3t3-to-Polyhedron-td4467182.html
In the first post I gave a link by Lehtonen Matti, and commented about it,
and I believe you gave me an older link of the same guy. I pointed out that
he uses a different interface, and even after making the changes it still
didn't work.
If you look at the file CGAL/IO/Complex_3_in_triangulation_3_to_vtk.h,
2. I saw the facets enum in a complex, but the whole doc is a bit obscure
about c3t3. And yes, if I spend a few days on this, I believe I could write
something. It would have been easier if I knew how to detect if a facet
belongs to the boundary, and how to discern between the different domains of
the complex. I might be mixing definitions, since I didn't fully understood
the doc. I need to read it again, and a depiction like in the polyhedron doc
would have surely helped . Since I don't need it urgently, I prefer to look
for an already made code - someone said he would fix the one on your link.
you will see that it's easy to either write it to an off or write a polyhedron modifier to extract the boundary on the mesh,
To get the subdomain of a facet f, use f.first->subdomain_index().
3. I am more curious about the difference between the two mesh generation
algorithms, the one for c2t3 and the one for c3t3. Theuy both seem to rely
on [BO05], which basically uses 3D restricted delaunay. As such I also
wondered, if the c3t3 would have generated a surface (polyhedron), would it
be, as expected, the same surface generated by c2t3?
Why the c2t3 is still buggy,Why are you saying that? do you have a bug report?
why the c3t3 doesn't have an official polyhedron converter, andMainly because a c3t3 contains information about a volumetric mesh, not
a surface mesh. I agree in some case it can be useful.
why each (c3t3, c2t3) is in a different package?Same as above, they are not made for the same purpose.
However you are right that a c2t3 can be represented within a c3t3.
In a near future, the surface mesher package will reuse some
functionality of the volume mesher,
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Convert-C3t3-to-Polyhedron-tp4467182p4497593.html
- [cgal-discuss] Convert C3t3 to Polyhedron, Zohar, 03/12/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/13/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/20/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/20/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/22/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/23/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/23/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/24/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/25/2012
- Re:Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Yan Shijiang, 03/25/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Philipp Moeller, 03/25/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/25/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Sebastien Loriot (GeometryFactory), 03/26/2012
- [cgal-discuss] Re: Convert C3t3 to Polyhedron, Zohar, 03/27/2012
- Re: [cgal-discuss] Re: Convert C3t3 to Polyhedron, Laurent Rineau (GeometryFactory), 03/27/2012
