cgal-discuss - 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
  • To: <>
  • Subject: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
  • Date: Tue, 10 Apr 2012 08:29:19 +0800
Hi, Pedro,
In most cases, copy needed .dll to the same folder will solve this question. I think I cannot find the reason and solution without trying myself.
But I recommend you to utilize dependency walker (http://www.dependencywalker.com/) to find out which dll is missing? Does copied dll match
the missing dll?
Hope this could help.
Yong xiao.
发件人: Pedro Alexandre de Araújo Gomes Lapido Loureiro [mailto:]
发送时间: 201249 23:13
收件人:
主题: Re: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
Hi, xiao yong, thank you for your reply.
I've copied this dll for the /debug folder.
Now, another runtime error complains of boost_thread-vc100-mt-gd-1_47.dll is missing.
Even copying this library for the same folder does not solve the issue...
Any ideas?
Regards.
Pedro.
Em 9 de abril de 2012 03:56, xiao yong <> escreveu:
Perhaps you should add dll created by cgal to windows/system32. Or add the path of  the folder of dlls to the environment variable ‘path’.
Or for simplicity, you can copy these dlls to the same folder  witch .exe file.
Edward
发送时间: 201248 22:36
收件人:
主题: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
Hello,
when I try to execute the demos in CGAL 4.0, compiled with VS 10, there is a system error saying the library
was not found.
The project was configured and generated with cmake - 2.8.7 in release mode.
Would you have any suggestions?
Regards,
Pedro.
