- To:
- Subject: Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
- Date: Fri, 13 Apr 2012 16:15:26 +0200 (CEST)
Hi
i had the same pb with the same configuration.
I reinstalled boost 1.17 and now boost_thread-vc100-mt-gd-1_47.dll is located
in C:\boost\boost_1_47\lib\
Do not forget to add the boost PATH in your environment variables (cf
attachement)
----- Mail original -----
De: "daisy"
À:
Envoyé: Vendredi 13 Avril 2012 15:26:52
Objet: Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
Hi,
I met the same problem with you when I tried to launch the
width_simplex.exe under the directory: C:\Program
Files\CGAL-4.0\examples\Width_3\Debug. (I think I configured and generated
with cmake - 2.8.7 in debug mode. I am not sure.) However, I can't find the
file /boost_thread-vc100-mt-gd-1_47.dll/ anywhere. I also don't know if I
find the file, where should I put it. Once you solve your problem, can you
write your method here or e-mail to me. By the way, where can I find the
file /boost_thread-vc100-mt-gd-1_47.dll/?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-vc100-mt-gd-4-0-dll-not-found-tp4541056p4554820.html
Description: JPEG image
- [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, Pedro Alexandre de Araújo Gomes Lapido Loureiro, 04/08/2012
- 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, xiao yong, 04/09/2012
- Re: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, Pedro Alexandre de Araújo Gomes Lapido Loureiro, 04/09/2012
- 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, xiao yong, 04/10/2012
- Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, Pedro Alexandre de Araújo Gomes Lapido Loureiro, 04/10/2012
- 答复: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, xiao yong, 04/11/2012
- Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, daisy, 04/13/2012
- Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found, gwenaelle . marquant, 04/13/2012
