cgal-discuss - Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
  • From: Pedro Alexandre de Araújo Gomes Lapido Loureiro <>
  • To:
  • Subject: Re: 答复: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
  • Date: Tue, 10 Apr 2012 13:52:27 -0300
Hi Yong,
I've followed your suggestion about using dependencywalker.
The output is somewhat cryptic for me:
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
The problems seem to be in:
c:\windows\system32\SHLWAPI.DLL and c:\windows\system32\IEFRAME.DLL
But these libraries are there.
Regards,
Pedro.
Em 9 de abril de 2012 21:29, xiao yong <> escreveu:
Hi, Pedro,
In most cases, copy needed .dll to the same folder will solve this question. I think I cannot find the reason and solution without trying myself.
But I recommend you to utilize dependency walker (http://www.dependencywalker.com/) to find out which dll is missing? Does copied dll match
the missing dll?
Hope this could help.
Yong xiao.
发件人: Pedro Alexandre de Ara
újo Gomes Lapido Loureiro [mailto:]
发送时间: 201249 23:13
收件人:
主题: Re: 答复: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
Hi, xiao yong, thank you for your reply.
I've copied this dll for the /debug folder.
Now, another runtime error complains of boost_thread-vc100-mt-gd-1_47.dll is missing.
Even copying this library for the same folder does not solve the issue...
Any ideas?
Regards.
Pedro.
Em 9 de abril de 2012 03:56, xiao yong <> escreveu:
Perhaps you should add dll created by cgal to windows/system32. Or add the path of  the folder of dlls to the environment variable ‘path’.
Or for simplicity, you can copy these dlls to the same folder  witch .exe file.
Edward
发件人: Pedro Alexandre de Araújo Gomes Lapido Loureiro [mailto:]
发送时间: 201248 22:36
收件人:
主题: [cgal-discuss] CGAL-vc100-mt-gd-4.0.dll not found
Hello,
when I try to execute the demos in CGAL 4.0, compiled with VS 10, there is a system error saying the library
was not found.
The project was configured and generated with cmake - 2.8.7 in release mode.
Would you have any suggestions?
Regards,
Pedro.
