cgal-discuss - Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons
  • To:
  • Subject: Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons
  • Date: Tue, 17 Apr 2012 12:11:23 +0200
A simple to implement method (but far from optimal) is to compute the
intersection of triangles from A with triangles from B (using [1] for example).
You then have a set of segments, triangles and points (or nothing in
the case the polyhedra don't intersect).
You simply need to compute the convex hull of all the endpoints of the
segments and triangles, and the points using [2].
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d/Chapter_main.html
[2]http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Convex_hull_3/Chapter_main.html#Subsection_16.2.3
On 04/17/2012 11:51 AM, sgdimitris wrote:
I would like to ask which is the easiest and fastest way to calculate the
intersection of two *CONVEX* 3D polyhedrons?
I *don't* want only to see if the two polyhedrons are intersected but also
to calculate the polyhedron that is their intersection!
Best regards,
Dimitris
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Intersection-of-two-CONVEX-3D-polyhedrons-tp4564202p4564202.html
