- To:
- Subject: Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons
- Date: Tue, 17 Apr 2012 12:30:14 +0200
Hi everyone,
I'm also interested in this problem using CGAL, as well as a similar one.
I've found an article [3] where a polyhedron is intersected with a plane
using the approach of first clipping all the faces, and then using the
face-edge connectivity information, capping the polyhedron with a final face.
This should be quite fast in CGAL if a dynamic data structure (a linked list)
is used for the half edge data structure of Polyhedron_3.
Is there an algorithm that could deal with non-convex polyhedrons with
non-planar faces? Nef_3 deals with non-convex polyhedra, but not those with
non-planar faces.
Would it be very inefficient if I have non-convex polyhedra to intersect, and
I create a 3D triangulation of the polyhedra, obtain a bunch of tetrahedrons,
and intersect the resulting sets of tetrahedrons?
[3]http://www.springerlink.com/content/v3403227110614q0/
> ----- Original Message -----
> From: Sebastien Loriot (GeometryFactory)
> Sent: 04/17/12 12:11 PM
> To:
> A simple to implement method (but far from optimal) is to compute the
> intersection of triangles from A with triangles from B (using [1] for
> example).
> You then have a set of segments, triangles and points (or nothing in
> the case the polyhedra don't intersect).
> You simply need to compute the convex hull of all the endpoints of the
> segments and triangles, and the points using [2].
> Sebastien.
> [1]
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Box_intersection_d/Chapter_main.html
> [2]http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Convex_hull_3/Chapter_main.html#Subsection_16.2.3
> On 04/17/2012 11:51 AM, sgdimitris wrote:
> > I would like to ask which is the easiest and fastest way to calculate the
> > intersection of two *CONVEX* 3D polyhedrons?
> > I *don't* want only to see if the two polyhedrons are intersected but also
> > to calculate the polyhedron that is their intersection!
> > Best regards,
> > Dimitris
> > View this message in context:
> > http://cgal-discuss.949826.n4.nabble.com/Intersection-of-two-CONVEX-3D-polyhedrons-tp4564202p4564202.html
> > Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, sgdimitris, 04/17/2012
- Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, Sebastien Loriot (GeometryFactory), 04/17/2012
- Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, Olivier Devillers, 04/17/2012
- [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, sgdimitris, 04/18/2012
- Re: [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, Olivier Devillers, 04/19/2012
- [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, ochyomdu, 04/19/2012
- Re: [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, Sebastien Loriot (GeometryFactory), 04/19/2012
- Re: [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, Olivier Devillers, 04/20/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, Tomislav Maric, 04/17/2012
