- To:
- Subject: Re: [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons
- Date: Fri, 20 Apr 2012 09:02:11 +0200
Olivier is right.
Note that for the dualization, you also need exact constructions as the dualization is a construction. Exact_predicates_exact_constructions can be used for that.
You do not necessarily need exact construction. Exact computation has two effects: ensuring robustness of the algorithms
and a guarantee of the exactness of the result. If you allow approximation during dualization, you still
have robustness during the convex hull using epick.
if you have no vertical faces in your polyhedron, you can use dualization by
plane z=ax+by+c <----> point (a,b,c)
since you do not make computation during dualization and thus do not need exact construction here.
The remaining point is the computation of the representation of input polyhedra has intersection of half spaces
(it uses computations if the real input is the vertices of the polyhedra).
- [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, sgdimitris, 04/17/2012
- Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, Sebastien Loriot (GeometryFactory), 04/17/2012
- Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, Olivier Devillers, 04/17/2012
- [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, sgdimitris, 04/18/2012
- Re: [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, Olivier Devillers, 04/19/2012
- [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, ochyomdu, 04/19/2012
- Re: [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, Sebastien Loriot (GeometryFactory), 04/19/2012
- Re: [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons, Olivier Devillers, 04/20/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] Intersection of two CONVEX 3D polyhedrons, Tomislav Maric, 04/17/2012
