cgal-discuss - Re: [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons
  • To:
  • Subject: Re: [cgal-discuss] Re: Intersection of two CONVEX 3D polyhedrons
  • Date: Thu, 19 Apr 2012 16:24:16 +0200
Le 4/19/12 3:32 PM, ochyomdu a écrit :
Hallo Dimitris.
The easiest way to calculate intersection of two polyhedrons is using of
class Nef_Polyhedron_3.
If You need to use some functions from Polyhedron_3 You can just convert
Polyhedron_3 into Nef_Polyhedron_3 (using constructor), calculate
intersection of polyhedrons and convert the resulting Nef_Polyhedron_3 into
Polyhedron_3 back (using function convert_to_polyhedron()).
Intersection is calculated with operation *
N1*N2
You find more information about Nef_Polyhedron_3 here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3/Chapter_main.html
yes,
but it will be quite inneficient if the two polyhedra ere known to be convex.
by dualization and convex hull you will do it in (N1+N2)log(N1+N2)
(and nef-polyhedra deals with very special cases (degenerate) but for that
they require exact arithmetic and it costs some time)
