- To:
- Subject: [cgal-discuss] No lib folder in the cgal installed directory
- Date: Wed, 18 Apr 2012 01:51:16 -0700 (PDT)
windows, vs2005, boost1_4_7, cmake2.8.7, no qt
After I installed the cgal and use cmake configured it, I found no lib
folder under the directory C:\Program Files\CGAL-3.5
http://cgal-discuss.949826.n4.nabble.com/file/n4567084/%E6%8D%95%E8%8E%B7.jpg
So, when I build the examples of the cgal, errors occured. What's the
matter? Why there's no lib folder?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/No-lib-folder-in-the-cgal-installed-directory-tp4567084p4567084.html
- [cgal-discuss] No lib folder in the cgal installed directory, daisy, 04/18/2012
- Re: [cgal-discuss] No lib folder in the cgal installed directory, Sebastien Loriot (GeometryFactory), 04/18/2012
- [cgal-discuss] Re: No lib folder in the cgal installed directory, daisy, 04/18/2012
- Re: [cgal-discuss] Re: No lib folder in the cgal installed directory, Philipp Moeller, 04/18/2012
- Re: [cgal-discuss] No lib folder in the cgal installed directory, Laurent Rineau (GeometryFactory), 04/18/2012
- Re: [cgal-discuss] No lib folder in the cgal installed directory, Sweety Pie, 04/18/2012
- Re: [cgal-discuss] Re: No lib folder in the cgal installed directory, Laurent Rineau (GeometryFactory), 04/18/2012
